Advancing stock timing? Any Gains?
Old Oct 9, 2015 | 12:00 PM
1987L69's Avatar
Car: 1984 Z28
Engine: LG4 305/4bbl for now
Transmission: 5-Speed
Axle/Gears: 3.23 Posi
I know its not a 3rd gen question but it is a L69 HO question. I have a stock 1987 Monte Carlo SS, stock timing says 6*, with all of the computer controlled Carb and distributor will it be worth bumping up the timing at all? i know this was a good trick with the older cars to give you a more "seat of the pants" feel, but Im not very familiar with the OBD1 carb/dizzy set ups. any input would be great!
Old Oct 9, 2015 | 03:37 PM
Piston454's Avatar
Car: 1990 RS Camaro
Engine: 400 sbc throttle body
Transmission: world class t5 manual
Axle/Gears: 3.73's, Detroit TrueTrac
Re: Advancing stock timing? Any Gains?
it would help some by maybe bumping it up a few more degrees but if you are unable to change the "initial timing" parameter in your computer it wont help much because your engine will be at say....8* advance but your computer still thinks it is at 6* which will result in your fuel being delivered into the engine at the wrong time.
Old Oct 10, 2015 | 03:25 PM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Please delete that reply!
Seriously, it makes no sense.
OP, the L69 chip has a fairly aggressive advance curve, so it won't tolerate quite as much static timing increase (as the lower performance CCC-Qjet cars will) until the power starts to fall off at the upper part of the advance curve and/or it detonates.
BUT.....it's definitely worth experimenting with. Gains will differ from car to car because of mechanical tolerances/variations. With the L69 chip in the car in my sig when it still had the LG4 engine, I ran about 12 degrees static timing for best performance, as measured by 1/4 mile trap speed. I'm told most L69 cars don't want quite that much, which is understandable considering the timing map in that chip.
Old Oct 10, 2015 | 06:46 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
^^^^Agreed
1983 LG4 Pontiac Grandprix
1985 L69 Monte Carlo
1983/1984 G20 Van LE9 305 (601 heads)
Old Oct 11, 2015 | 09:28 AM
1987L69's Avatar
Car: 1984 Z28
So it would be better just to enjoy what i have, I no longer live near a track to try different timing set ups for real ET changes.
strayli
Dec 31, 2022 12:44 PM
xbazzarex
Dec 1, 2015 05:25 PM
KarlJ
Nov 13, 2015 09:48 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
timonator
Sep 11, 2015 05:11 PM
