406 SBC Dyno Results. Thoughts?
Old Oct 11, 2015 | 10:31 PM
87v6Bird's Avatar
Car: 87 Firebird, 89 Trans Am
Engine: 406, LB9
Transmission: T56, 700R4
Axle/Gears: 3.23 Torsen, 2.73 Posi
I went to a car show on Saturday and at the show they had a dyno. I've been curious what my car was putting out since I got it together and worked out most of the kinks so I went home, retrieved it and made a run.
Bottom line 250 rhwp @ ~4100 rpm and 375 rwtq @ ~3250 rpm
Engine Specs:
406 SBC, rebuilder dished pistons, assuming ~9:1 compression
Holley 750 CFM Vac. Sec.
Comp 268H 12-210-2, 218/218, 0.484/.484 (1.6 Roller Rockers)
Promaxx 2180 heads, 64cc chamber, 190cc intake runner
Summit 226010 intake (Weiand Speed Warrior copy)
Hedman 68460 headers into 2.5" dual exhaust w/ Dynomax muffler
36 deg total timing
The dyno sheet they provided doesn't have RPM's. I pulled into it into a plot digitizer and backed out some data points which you can see In the Excel sheet. I know there are no AFRs given but I can say at WOT it's around 13-12.5. I don't think it's perfect there yet but this was a spur of the moment thing.
File Type: xls
Old Oct 11, 2015 | 10:58 PM
cardo0's Avatar
Car: Fourth Gen '94 camaro
Engine: 350 Gen II
Transmission: A4
Re: 406 SBC Dyno Results. Thoughts?
Dynojet has the worst rep for accuracy. Use it for a tuning tool only. The spreadsheet power curve looks correct in shape for that cam though numbers look low while the torque numbers look ok.
Ill guess thats a fun car to drive and wheel spin is a problem. Just remember no one races on the dyno.
Old Oct 12, 2015 | 07:24 AM
87v6Bird's Avatar
Engine: 406, LB9
I agree. I thought HP was low as well. Torque not as much. I need to get to the track. The one time I made it with my car this year they had canceled test and tune.
It's definitely fun to drive.
Here's a vid of the run. For some reason I can't get the video to embed. Here's the link.
https://drive.google.com/open?id=0B5...Hhha0ctYkcwR0U
Old Oct 12, 2015 | 07:50 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
See what it runs but its a mild combo. Would have thought it would make alittle more than that but it is a small cam and intake
Old Oct 12, 2015 | 08:01 PM
87v6Bird's Avatar
Engine: 406, LB9
That's the plan. Hopefully I can make it out next Sunday.
bluegoose
Feb 11, 2003 01:14 PM
bluegoose
Jan 4, 2003 02:32 PM
Nate1
Sep 19, 2002 07:40 AM
LilJayV10
Aug 22, 2002 08:15 PM
breathment
Aug 9, 2002 11:51 PM
