Idle problems
Old Oct 20, 2015 | 08:43 PM
mb2hurley's Avatar
Car: 91 camaro rs
Engine: v6 :/
Transmission: auto
Idle problems
91 camaro rs v6 automatic
Car started to idle high around 5000, found several bad hoses and replaced them and brought it down to 4000. New plugs, wires, cap and rotor and a new iac valve, reset ecm and started just fine idle good but then slowly got higher and higher raised 200 rpms every 5 seconds til back to 4000, when shift into drive rpms drop to about 2000 but shot back up to 4000 in park or neutral, sprayed starting fluid around hoses and throttle body, no signs of any more vacuum leaks, any ideas?
Old Oct 20, 2015 | 11:01 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Idle problems
It never hurts to check the timing. I would set it to the stock setting.
I looked on line and 10* BTDC is stock for all 2.8L and 3.1L engines.
( EST wire disconnected and engine at operating temperature )
Gunner242
Dec 25, 2015 04:49 PM
charlie1011
Oct 11, 2015 02:26 PM
meeklay812
Oct 1, 2015 03:46 PM
Giocio
Oct 1, 2015 12:20 PM
challenger71
Sep 10, 2015 04:58 PM
