What lift Cam to use?
Car: 1984 Z28
Engine: 305H.O Modified
Axle/Gears: 973
1984 305 H.O. 700R4
I have stripped all smog and computer controls . I'm running a MSD HEI distributor and Holley 650DP carburetor. I have installed Flow Tech Header and true dual exhaust w/ Hushmasters.
I am unsure what lift and duration cam to use. Engine runs to good to warrant a rebuild and cant afford a set of heads at this point.
Car: 89 Firebird
Engine: 355 TBI
Re: What lift Cam to use?
I did the exact thing with an Lg4 which shares the same heads as your L69. I believe I used a Summit K1103 kit best I remember and it dropped a second in quarter mile from my baseline putting it in the 14s. It would have done much better with some gears and higher stall torque converter but still hit in the high 14s. Much better than it was stock.
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 1984 Z28
Axle/Gears: 973
Car: 89 Firebird
Engine: 355 TBI
