Finally ran a solid 11, with may car
Old Oct 28, 2015 | 10:58 AM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
I have wanted my daily driver very streetable Firebird to run 11's with ease for the last few years. Well it finally did it. I ran a 11.72 at 116 MPH and an 11.62 at 116 MPH. (I could not find the 11.62 slip so I have the 11.72 pictured). I have attached the run and a picture of my car when I was on Drag week this year.
The car would only run 12.0 with the 3.54 gears and the 6-speed with my race weight of 3700 LBS. It would bog out of the hole when the tires dead hooked with the alum flywheel. I switched to 4.10 gears and the bog disappeared and the car ran hard. I spun on these runs so I expect that I could get mid 11's with some practice on the launch.
Old Nov 2, 2015 | 09:29 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: Finally ran a solid 11, with may car
was that 8th mile ? or the real deal 1320 ?
Old Nov 2, 2015 | 09:34 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Nice. My dad built a 406 and ran 11.30s in a 67 chevelle, drove it on the street too. It wasn't fuel injected though. Very nice timeslips man!
Old Nov 2, 2015 | 04:19 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Excellent. Time to get collectors plates for it.
Old Nov 2, 2015 | 05:47 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Looking at the timeslip numbers, it's 1/4 mile. He did 7.47 @ 91.22 in the 1/8.
Old Nov 2, 2015 | 06:13 PM
Damon's Avatar
Good call on 4.10s with the 6-speed. I had a 94 Formula 6-speed with stock 3.42 gears and it had the same problem- bogged if you got it to hook good. Likewise, I put a set of 4.10s in it and the problem went away (plus you can actually USE 6th gear for something other than highway fuel economy).
Dead stock on street tires my Formula run 13.5 @ 105. On DRs with the 4.10s it would go a maddening string of 13.0s but I could never crack an 12.99 with it. Still, for a dead-stock LT1 car (not even a cold air kit) people were generally shocked it ran as well as it did. Even the (then new) LS1 cars that were usually in my rear view mirror if they were stock.
You still running the 7.625" 10 bolt? If so, prepare to upgrade. It won't put up with 1.6 60-foot shenanigans for long. Especially not if you get it to dead-hook.
Old Nov 7, 2015 | 09:16 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
Thanks for the reply. I have a Strange S60 rear end in the car. The stock 9-bolt worked pretty well until I started running mid 1.6's and then I blew two of them very quickly so I put the S60 in.
Old Nov 8, 2015 | 08:03 PM
cardo0's Avatar
Car: Fourth Gen '94 camaro
Engine: 350 Gen II
Transmission: A4
Pretty cool car. Thx for sharing your combination. Thats pretty fast for that size cam. I think u got it figured out.
Congrats.
Old Nov 8, 2015 | 09:05 PM
BrutalGTA's Avatar
Car: 1989 GTA
Engine: LS coming soon
Transmission: 80E coming soon
Axle/Gears: S60/35 Spline/S-Trac/3.73
How is your formy 3700lbs???
My 92 was 33xx with a RAII hood.
Old Nov 8, 2015 | 09:09 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Nice and I approve of the car too!
Old Nov 10, 2015 | 01:40 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
That is with a 200 lb driver.
The car was 3375 lbs stock, added in T56 over T-5 added extra weight, added in S60 over 9 Bolt that added an extra 100 lbs.
Old Nov 10, 2015 | 02:17 PM
BrutalGTA's Avatar
Car: 1989 GTA
Dang, didn't realize the S60 is so damn heavy. Nice times either way!
Old Nov 10, 2015 | 03:46 PM
TTOP350's Avatar
How about a pic of the engine?
birdman_29
Jan 7, 2017 08:24 AM
KarlJ
Nov 13, 2015 09:48 AM
tommy z-28
Oct 6, 2015 10:58 PM
okfoz
Sep 17, 2015 10:30 AM
6speedIROC
Sep 13, 2015 01:29 PM
