Dash Lights
Car: 1990 RS, 2002 Chev Silverado
Dash Lights
The speedo half of my dash lights doesn't come on until I drive for a while. Is there a separate connection for them? Any ideas what is wrong?
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Re: Dash Lights
You probably have a short on somewhere on the back of the cluster. There is a printed flexible circuit on the back of the cluster and every once in a while the bulb connections melt. It is a fairly easy fix by using a multi-meter to check for continuity and then painting on a special liquid metal solution. You can find it online, or some parts stores carry it.
