excessive vibration at around 2000rpm
Old Oct 28, 2015 | 06:44 AM
sjorgens's Avatar
Car: 1984 Firebird Trans am
Engine: 5.0 HO 4BBl
Transmission: one that kind of works
Axle/Gears: some that turn the wheels
I have noticed that whenever I am running my car at about 2000rpm within 200 rpm above or below that my car seems to vibrate quite a bit. It feels almost like I'm going over a very textured road surface. This is in overdrive or drive. This is with stock transmission on a 1984 trans am with the H.O. engine.
I can't tell if it's an engine issue or maybe something else? Engine seems to be running fine otherwise. Maybe it needs a wheel alignment?
Last thing that was replaced on the front end were the ball joints. My mechanic said i didn't need a wheel alignment, so I am wondering if that assessment was incorrect?
cheers in advance guys.
Old Oct 28, 2015 | 06:56 AM
ex-x-fire's Avatar
Re: excessive vibration at around 2000rpm
Pull the driveshaft & check for a loose or frozen u joint.
Old Oct 29, 2015 | 03:37 PM
Piston454's Avatar
Car: 1990 RS Camaro
Engine: 400 sbc throttle body
Transmission: world class t5 manual
Axle/Gears: 3.73's, Detroit TrueTrac
its obviously a balancing issue some where. sometimes the balancing weights come off the drive shafts.
KarlJ
Nov 13, 2015 09:48 AM
tommy z-28
Oct 6, 2015 10:58 PM
InfinityShade
Sep 18, 2015 08:32 PM
funkyTA
Sep 10, 2015 06:38 PM
84 TA NV
Sep 6, 2015 08:02 PM
