Odd smoking problem
Old Nov 16, 2015 | 12:25 AM
Jonny45's Avatar
Car: 1988 Firebird
Engine: Built 3.4 swap
Transmission: worldclass T5
Axle/Gears: 3.23 28 spine posi with moser axles
Odd smoking problem
I recently built a highly modded 3.4 it currently has about 150 hours
The past few weeks its smokes only under hard throttle and i have noticed coolant going down the past week
Engine has 3-5% leak down and 140-145psi threw out the engine....any help is appreciated
Old Nov 17, 2015 | 08:24 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Odd smoking problem
Sounds like a head gasket is leaking. Is the smoke a whitish color?
RBob.
Old Nov 17, 2015 | 10:01 PM
tyeo098's Avatar
Car: 88 Chimera
Engine: 1994 LO5 5.7L
Axle/Gears: 2.73...?
Missing coolant, smoking... yup. Your engine is eating the coolant it seems.
Is your oil frothy? Wouldnt a leaking headgasket show up obviously on a compression test?
Old Nov 18, 2015 | 12:25 AM
Jonny45's Avatar
Car: 1988 Firebird
No the oil is still clear and looks great. It runs WAY to well to be a headgasket i think?
The smoke is white for sure
Could the intake gaskets be leaking?
Old Nov 18, 2015 | 08:22 AM
tyeo098's Avatar
Car: 88 Chimera
The intake gasket would likely leak into the lifter galley and mix with the oil...
Have you pulled your plugs and inspected them? Maybe the intake gasket blew in to 1 cyl adjacent to the pass through.
Old Nov 18, 2015 | 11:44 AM
Jonny45's Avatar
Car: 1988 Firebird
Plugs look good no white spots from the coolant and no carbon build up.
Ill add its only when its hot
Knight Prowl
Exterior Parts Wanted
Dec 7, 2015 10:40 PM
joef2002
Nov 15, 2015 12:02 PM
ndndndnd
Nov 13, 2015 07:36 AM
angelr
Nov 10, 2015 05:44 PM
