Starter problem
Old Nov 20, 2015 | 10:28 PM
1982firebird7's Avatar
Car: 1982 Pontiac Firebird
Engine: 2.8L V6(upcoming 350 Swap)
Transmission: "World Class" T5
Starter problem
My 1982 Firebird V6 wouldn't start when i bought it so i figured it was the starter, soon enough it started because of a faulty clutch switch. Before i figured that out it had started right up. Except it was before that, that i knew there was a clutch switch problem. I took the starter out got it tested. it was fine. I put it back in, shims and all, and now it sounds like the gear is slipping on the flywheel, it cranks very slowly but will not turn over. I wired everything up, just as it was before. And im having problems now. Is my starter actually not good?
Old Nov 24, 2015 | 02:31 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Re: Starter problem
Not unusual for a starter to do that. My 89 (V8 engine) was doing the same thing. Replaced the battery, seemed to help for a while but it was actually the starter. Replacement was dirt cheap at Advance, Mexican rebuild these days. Under $50.
Old Nov 24, 2015 | 09:35 PM
Re: Starter problem
okay thanks man
formula1988
Apr 6, 2005 01:32 PM
gholian
Jun 25, 2003 02:36 PM
BKautomotive
Jun 27, 2001 07:55 PM
