Loose dipstick tube
Old Dec 20, 2001 | 11:49 PM
SgtSkip's Avatar
Loose dipstick tube
Will it hurt anything if its loose? How do I tighten it? Mine moves around really easy.
Old Dec 20, 2001 | 11:51 PM
Joshua Leslie's Avatar
althogh its not the original engine, my dipstick has a bracket so you can bolt it to the exaust and hold it in place. And just to make sure it doesent leak, I ran a bead of silicon around the base where it seats.
I know that somedipstiks are the press in type, so I guess it just depends on what you have.
My dipstick is from an older truck, for some reason, the press in type would not fit.
Old Dec 21, 2001 | 03:51 PM
MotorCityMuscle's Avatar
Joshua Leslie: I have the same problem. A press in replacement dip stick absolutely will not fit into the hole. What did you do about it? What stick and what is its part number? I am out of ideas and was considering plugging the hole altogether. TIA.
Old Dec 21, 2001 | 05:37 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
I bought a replacement tube and stick from GM. It does have the tab to mount to the exhaust. If you don't have this tab, I would strongly suggest getting one. No matter what I did, the push in type always leaked for me. The chrome ones were the worse. Just an idea.
Old Dec 21, 2001 | 05:55 PM
MotorCity, I went to Mathew Hargraves Chevrolet in Royal Oak, and told them I wanted a drivers side dipstick from a pickup truck, not a press in type.
I think but am not certain they told me they didnt have one and it would have to be pass. side dipstick, but I said thats fine.
I think but am again not certain that it is from a truck.
I dont have a part number, sorry!!
It was black. sticks out of the engine about 12-18 inches or so, and has a bracket on it to bolt it to the exaust.
Old Dec 21, 2001 | 08:58 PM
Vader's Avatar
Sarge,
If the tube already moves around easily, remove it. Swage the end with a punch or refrigeration tube swaging die, then press it back in the clean hole with a bit of LocTite 262 or equivalent. It'll probably stay then.
Old Dec 22, 2001 | 12:58 AM
SgtSkip's Avatar
Good to go. Thanks all. I think I'll try your idea first Vader. Sounds like a simple but good solution.
BTW, you can thank the Black Knights of VMFA-314 from for that awesome strike on the Taliban convoy today! Semper Fi!
gixxer92
May 18, 2017 11:20 AM
no green
Jan 9, 2016 09:22 PM
NZKnight
Oct 15, 2015 02:47 PM
FormulasOnly
Oct 2, 2015 05:52 PM
zman1969
Oct 1, 2015 11:09 AM
