Timing
Old Dec 2, 2015 | 07:32 PM
Terry0690's Avatar
Timing
What are some of the issues that timing being off would cause I recently had to put a 2.8 back in my 89 camaro rs but when it was first fired back up I made a dumb mistake of not checking the plug wires 2 cylinders did not have a wire on now the car runs like crap there is no power shakes when in gear and you hit the gas and chugs horribly the engine ran strong when I took it out but now I'm at a stand still any help is greatly appreciated
Old Dec 3, 2015 | 02:45 PM
Piston454's Avatar
Car: 1990 RS Camaro
Engine: 400 sbc throttle body
Transmission: world class t5 manual
Axle/Gears: 3.73's, Detroit TrueTrac
Re: Timing
timing being off would cause lack of low-end power. slow to accelerate, thats basically it. do you even know where your timing is set at? stock they were set at 0 degrees. but you could bump it up to 6 degrees advance to give you a little more power. dont know if this really helps any.
Old Dec 3, 2015 | 06:51 PM
Re: Timing
Leave the timing alone. Forgetting to hook up plug wires won't affect it.
What happened when you put in a new set of plugs and hooked em all back up? Tried a new cap & rotor (since the rotor is probably now arced through in the middle and the cap carbon-tracked)?
Old Dec 4, 2015 | 12:31 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Timing
If your concerned about the timing in general check it like this.
Start car and idle until the car is at operating temp. Disconnect the EST wire, adjust timing, reconnect EST wire. Shut off car .
Old Dec 4, 2015 | 06:33 AM
Re: Timing
Don't mess with the timing.
Leaving plug wires off won't change it.
Messing with something unrelated won't fix the problem you actually have.
John1987formula
Apr 13, 2020 09:58 PM
Drone358
Jan 16, 2016 07:48 AM
Knight Prowl
Exterior Parts Wanted
Dec 7, 2015 10:40 PM
knightinblackar
Nov 12, 2015 04:46 AM
90formulaVortec
Nov 9, 2015 05:07 PM
