RED WHITE N BLUEGOTS ALOTS ON MY HANDS!!
Old Dec 2, 2015 | 07:47 PM
feelinsporty's Avatar
I have a
Red 91 5.0 Camaro TBI no interior new engine harness new dash and inside harness , engine is fine, on blocks
White 92 3.6 Camaro TBI everything is fine except for after driving 120 miles back and forth to school, wouldnt go above 30mph without reving up all the way, drives in second, I was told this was the trans
Blue 85 5.0 Firebird TPI - This one is tricky drove it about 40 miles and tried to start again, started to jerk alot, looked under the hood
EST was disconnect, two vacuum lines where not capped right, a connector behind the vacuum canister was disconnected, air filter was not on right, smell and oil leak,
It wont idle in park but will in drive, when you take you foot of the gas it stalls out, when stopping it stalls out, will idle manually in park and drive.
Pulled codes 13, 22, 32, 33, 45 does five codes mean the problems are not very big??
Which parts from my white and red car are interchangable?
This weekend im going to change the trans and engine oil.
Besides that where should I start???
bighitdb9
Mar 24, 2016 06:40 AM
NiG
Nov 13, 2015 05:43 AM
edpontiac91
Nov 12, 2015 03:27 PM
C-wade7
Nov 3, 2015 01:10 PM
AmpleUnicorn88
Interior Parts Wanted
Nov 2, 2015 09:33 PM
