Filter in fuel tank?
Old Dec 15, 2015 | 06:59 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
For a 1986 LG4, originally a mechanical fuel pump, NO pump in the tank, is there a filter at the pickup in the tank?
It has a new Carter electric pump below tank level. I get only a pulse of pressure when the pump starts, and it immediately returns to 0 psi on the gage with the pump still running. It sure looks like a clogged pickup to me, but I just wanted some assurance that I'm not dropping the tank for no reason. I've never seen the inside of a 3rd Gen tank.
Thanks in advance.
Old Dec 15, 2015 | 07:04 AM
Re: Filter in fuel tank?
Yes.
http://www.rockauto.com/catalog/more...nid=495&jpid=7
Rod the pickup tube out with a coat hanger while you're in there. Or better yet, just change it out. For that matter a new pickup probably will come with a new strainer sock.
Old Dec 15, 2015 | 07:16 AM
86LG4Bird's Avatar
Thank you, Sofa!
