Replacing heater core 1991 Camaro
Old May 1, 2001 | 04:11 AM
Matt_Ky's Avatar
Car: 1998 Camaro Z28
According to Chilton's, the right and left hush panel, upper dash pad, front speaker retaining nuts, both side window defrost ducts, radio trim plate, upper console trim,
emergency brake handle grip, trim plate under steering column, and lower the column all have to be removed.
Is it possible to replace heater core without removing all of the above?
I have coolant pooling in passenger side floorboard. I can see it dripping off a bolt holding a black box on passenger side
when I took the hush panel off.
BTW, this is an RS LO3 VIN "E" with 39,500 miles.
Matt
Old May 1, 2001 | 08:08 AM
El Guapo's Avatar
I managed to get by with only removing Radio/HVAC bezel, the ducting behing the HVAC bezel, and the pass side kick panel. Now this was on an 85 and 87 model birds. Your 91 could be a different animal as far as trim removal goes.
Also, you will need two 12" 1/4" extensions and a universal, plus be good at getting your hands in TIGHT places.
Here http://www.sethirdgen.org/heater.htm is a Tech article wrote, IIRC, by GMTech. It is what I followed and I got the job done.
Good luck to ya.
Clayton
Old May 1, 2001 | 08:43 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
It's been a few years, but I didn't do anything from the top or driver's side of the dash. Everything was done underneath the passenger side. Those 9/32" bolts along the top of the core box were a pain to get to... I think I left a few out on purpose when I put the thing back together.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old May 1, 2001 | 09:06 AM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
well i know on mine (86) i just yanked the kick panel, pulled some ducting and go to it fromtherer.. good ol 1/4 ratchet set ehhe
Steve
Old May 2, 2001 | 02:16 AM
Matt_Ky's Avatar
Any 1990-1992 Camaro owners performed this before that could share their experiences?
Apparently, it is alot easier on the earlier third gens's since nothing on the top, ie dash pad or drivers side has to be removed.
Matt
Old May 2, 2001 | 08:13 AM
El Guapo's Avatar
The only real difference should be the amount of Trim that needs to be removed. I cant imagine GM making a functional difference (like relocating, reattaching the heater core) that late in the run. So try it like we did. Worse case, you wind up frustrated, best case, you get it done easier than you thought.
Clayton
BTW Chiltons and all the others usually show you the easiest way. However, it usually is also the longest and most tedius way. So which do you want? Easy,Long; Hard, Fast.
Old May 2, 2001 | 04:28 PM
Matt_Ky's Avatar
El Guapo,
To answer your question, neither! Easy and fast works for me. Of course thats usually not how it works out when working on a car you are unfamiliar with. What I was hoping is to get a reply from a 1990-92 Camaro owner that has done this before. Yes, I realize Chiltons, Haynes and even Mitchell is generically written in some cases.
Thanks anyways.
Matt
Old Dec 15, 2015 | 02:09 PM
Sir ian's Avatar
Car: 1991 Camaro RS
Engine: V-8 305
Re: Replacing heater core 1991 Camaro
Anybody know where to get a replacement heater core?
Old Dec 15, 2015 | 06:22 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
have you checked your local auto parts store ? I'm sure they can get them . I think G.M. used the same htr. core on several different cars . good luck ...
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
