91 Firebird Speedo in an 89 Firebird
Old Dec 14, 2015 | 08:28 PM
kx3g's Avatar
Car: '89 Formula
Engine: L98 350
The odometer and tripometer in my 89 Formula have never worked, speedo works fine. Just picked up a 91 speedo. Will it work and be basically a plug and play in my 89? I haven't taken the old one out yet so I can't compare the guts of them yet. The 91 is a 120 mph and it is a 6 digit odometer.
Thanks in advance,
Old Dec 14, 2015 | 09:49 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: 91 Firebird Speedo in an 89 Firebird
Should work as long as the max speed is the same in both and it came out of an V8 and going to a V8.
Old Dec 15, 2015 | 10:35 AM
kx3g's Avatar
Car: '89 Formula
Engine: L98 350
My 89 has the 140 mph speedo. If I can't swap the entire speedo, do you think I could take the odometer out of the 91 (120 mph) speedo and swap it into my 89?
Old Dec 15, 2015 | 10:52 PM
antares57's Avatar
You can swap it out, but it may not give you an accurate speed reading. If the odometer is the same part should work.
89irocz355
Oct 8, 2023 12:59 PM
instaldave
Apr 18, 2016 07:38 AM
'91CamaroRS
Brakes
Dec 14, 2015 01:07 PM
88 350 tpi formula
Mid-West Region
Dec 10, 2015 07:44 AM
