more hp from my chevy 350
Car: 1982 camaro berlinetta
Engine: 5.7 350 swap
Transmission: th350 swap
Axle/Gears: 26 spline 7.5 ring gear
I have a 1977 sbc 350 4 bolt main & I want to get more hp from the engine it is rebuilt and I want to add vortec heads and a cam what should I get and how much hp would I be looking to get after?
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: more hp from my chevy 350
narrowing the scope of your question would help you get responses . what is the intended use ? street car or drag ?
Well I want a daily driver with power but I still want to street race it
Car: 97 Z71 Extended Cab
Engine: 5.7 Vortec
Axle/Gears: 3:42
The 1st thing you need to do is figure out exactly what you have.You say it's been rebuilt.That may not be a good thing if shorter rebuilders pistons were used.These piston may have a 1.540",or,1.548" pin hgt. vs the stock 1.56".These will sit lower in the bore at TDC,thereby lowering the compression & detonation resistance.On the other hand,someone may have used flat tops trying to raise compression for the smog heads that are stock to your engine.Going to Vortecs could raise the compression to up over 10:1.
Just swapping a set of Vortecs in place of a set of smog heads is a 30 to 50 HP gain on a stock 350 bottomend,depending on it's condition.
1st you need to identify which heads & pistons(dish,or flat top along with the volume of any dish) are currently in the engine,then you need to measure piston to deck hgt @ TDC,then you can lay out a plan to get where you need to be.
dpmalibu
Jan 25, 2016 12:13 PM
[For Sale] Comp Cams Ultra Gold and Summit rockers
FASTERTHANUMARK
LSX and LTX Parts
Dec 15, 2015 04:28 PM
ledman66
Dec 14, 2015 11:14 PM
