radiator question
Old Dec 21, 2001 | 04:57 PM
FAST85Z28's Avatar
radiator question
I have never had a radiator prob before... so im wondering...
My raditor leaks fluid when im at idle or a stop (prolly does it as im moving but i cant see that!) It just happened racently... Is this telling me that I should start looking for a new one.. Or should I first start off with trying Bars Leak or something, and if that doesnt work I should start seraching for a new one..
And if I should happen to have to get a new one, Whats the price range that I'm looking at.. 85 Z28 TBI 305
Thanks for the help,
John
Old Dec 21, 2001 | 05:16 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
have you changed the hoses recently?
maybe you cracked one of the tubes where you hook the hose up
another thought, are you sure that your water pump didn't give up the ghost? they leak from a drainage hole on the bottom of the pump usually..
Old Dec 21, 2001 | 08:13 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Like said above, I would check to make sure where the leak is coming from before you waste money on a radiator. Especially the hoses if they are old, or make sure they're still tight.
If you do have to replace it, I hear autozone sells them fairly cheap, but I wouldn't trust those. I got mine from Summit, Griffin aluminum 3core $180.
Old Dec 21, 2001 | 09:45 PM
Engine: 305TPI
the AutoZone radiators are good man..
i used to work there, 90% of ALL their radiators are aluminum not plastic..
they all have a lifetime warranty, as well..
Old Dec 21, 2001 | 10:06 PM
Car: 99 Formula
Axle/Gears: 342
They make plastic radiators?
Old Dec 21, 2001 | 10:11 PM
Engine: 305TPI
autozone or gm..
both rads on both of my IROCs are plastic.. the tanks are..
the ones at autozone have the metal tanks..
Old Dec 22, 2001 | 10:08 AM
FAST85Z28's Avatar
The leak is coming straight out the bottom, near the center.
Old Dec 23, 2001 | 12:01 AM
Engine: 305TPI
water pump..
see if there is water dripping out the drainage hole in the bottom of the pump..
Old Dec 23, 2001 | 12:28 AM
Car: 99 Formula
Axle/Gears: 342
I think he means at the center bottom of the radiator. I would double check though. I know one time, a hose came a little loose on me (the lower hose) and the antifreeze trickled out of the hose and along that metal railing that the radiator fits on. Make sure it isn't flowing from the hose along that railing.
Old Dec 23, 2001 | 10:55 PM
GTA88's Avatar
If you go the rad route.... I have an Autozone rad in my V8 daily driver. It's been in for a year. No probs. 3 row metal, for $73
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Ron U.S.M.C.
Sep 7, 2015 08:38 AM
Clean87TA
Sep 4, 2015 11:23 PM
redmaroz
Aug 16, 2015 11:40 PM
