Once again code 42 help.
Old Jan 12, 2016 | 04:14 PM
DemonYusuke's Avatar
Car: 1991 z28 L98 Spec
Engine: 5.7 350 TPI 245\345
Transmission: 700 R4
Okay guys I have been battling this issues for quite some time and it is getting very annoying. I have replaced everything to do with this code. It still refuses to go away. I have checked the wiring and the grounds and found nothing wrong. The car runs fine but feels sluggish (probably due to a bad injector). I have reseated the prom on the ecm I have tracked the white wire from D8 on the ecm and found nothing wrong.
99 times out of 100 the ses light is on, but every once in a blue moon, it goes away for like 10 minutes. (also note that my tachometer pegs at start up but will work every once in a while as well.)
Any advice guys, my next step is to replace the ecm or get a whole new harness. I really dont want to spend that kind of money for no real reason.
(ON another side note, i am dumping fuel, which i believe is my bad injector, but the car runs on all 8. Someone told me this is another sign of a bad ecm, but i just dont know.)
Old Jan 12, 2016 | 08:02 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: Once again code 42 help.
Follow the attachment and if that brings you to replace the ECM, replace it, Good luck.
File Type: pdf
Capone615
Feb 5, 2016 03:50 PM
hostile85
Jan 29, 2016 04:49 PM
Firechicken86
Jan 17, 2016 10:59 AM
carattini
Jan 12, 2016 12:51 PM
Onbusy
Mid-Atlantic Region
Jan 7, 2016 10:06 AM
