I finally got my engine block!
Old Feb 3, 2016 | 04:49 PM
Jake_92RS's Avatar
Car: 1992 Camaro RS, 2012 Camaro SS 45th
Engine: L03 305 TBI V8, Blown 6.2L LS3
Transmission: 700R4, TR6060
Axle/Gears: GM 7.6" 10 Bolt 2.73
So, I finally got that first piece of the adventure that is building an engine. Casting#: 3970010 w/ 4 bolt mains. Looks to be a pretty solid starter, especially when I picked it up for $125. Now the question is where should I start with block preparation? I know it needs to be crack tested and such, but where can most of the prep work be done? Thanks you guys.
Old Feb 4, 2016 | 12:45 AM
Night rider327's Avatar
Car: 1988 Camaro
Re: I finally got my engine block!
If it's just a bare block.. You don't need to do any prep work really. The machine shop will vat/hot tank clean it, check for cracks, remove old freeze plugs and cam bearings.
If it's a full engine, you can take it all apart. Just be sure to steel stamp number the rod beams, rod caps, and main caps.
If you want to smooth up the block, you can grind/sand all the outside surface with a die grinder, stones and sanding rolls. This would be done on like show car engines.
You can check the oil return holes in the lifter valley, timing chain area, etc and grind out any casting flash from the holes.
But that is pretty much it for the prep work on your end until it comes back from the machine shop.
After you get it back, then you wash, blow, brush, and dry the block. Tape it up and paint it. Then start building the engine
TA Dad
Dec 28, 2020 10:04 PM
BOTTLEDZ28
Jan 31, 2016 01:20 PM
2012sergen11
Jan 22, 2016 07:41 PM
84tr
Jan 10, 2016 04:34 PM
