two questions - picture included
Old Dec 22, 2001 | 04:34 PM
rezinn's Avatar
Hopefully that posted correctly. What else do I need to do to remove the heater core? What is the cable underneath? Thanks!
Old Dec 22, 2001 | 04:57 PM
rezinn's Avatar
forget the first question, Im done now.. but what is that cable?
Old Dec 22, 2001 | 07:19 PM
Pat Hall's Avatar
That's probably the cable that controls your hot to cold temperature. The rest of the heater functions, such as defrost, dash vents, or floor are controlled by vacuum servos.
Old Dec 22, 2001 | 07:27 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Pat's right, it works the door right there, which controls the mix of air that's been heated and air that hasn't. Hot water flows through the heater core all the time, or at least whenever the temp control is above full cold.
Old Dec 24, 2001 | 03:19 AM
TBIfly's Avatar
most definitely the heater control....
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
I'llrocya
Feb 2, 2016 11:43 PM
redmaroz
Aug 16, 2015 11:40 PM
Street Lethal
Aug 12, 2015 11:33 AM
