I ported my own heads...
Old Feb 16, 2016 | 08:01 PM
3rd gen money's Avatar
Car: 1992 camaro rs
Engine: 383 stroker
Last January I decided to port my aluminum l98 heads for my 383 stroker with a comp 286 cam (hydrolic). First I port matched the int to the edelbrock gaskets as well as my single plane Victor Jr intake. Then I port matched the exhaust to the edelbrock gaskets which are perfectly sized to the Doug's full length headers. (Both int and exh ports were TINY compared to the gaskets) Then I just started gutting out metal from the insides till it "looked right" and then smoothed it ok the best I could. Hopefully I didn't destroy a perfectly good set of heads lol....
Old Feb 16, 2016 | 09:57 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: I ported my own heads...
port matching is a good idea. many skip this step.
Old Feb 16, 2016 | 10:42 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
back in 1995, ported the original heads that came on my '84 vette 350 and it did make a noticeable difference Mostly I cleaned up the "flash" in the bowls,streamlined the guide bosses,and slightly raised the port roofs of intake and exhaust.The 'vette engine came with 76 cc '624s.
Old Feb 17, 2016 | 02:21 PM
mrestrictrplate's Avatar
Car: 87 Iroc 5.7,67 SS Camaro,90 Formula
Engine: 355 AFR Superram LPE 219
Transmission: 700r4 3000 stall 4spd 5 spd
I've done 100 intakes but I'm still afraid to touch heads myself. I know if you touch the wrong area you slow the velocity and can make them flow less. The little that you did i'm sure will make a difference so good for you. It's a good feeling you get with tinkering with porting, I like doing it.
mattbhm
Apr 24, 2016 09:08 AM
hectre13
Feb 8, 2016 09:28 AM
kairles
Feb 5, 2016 11:58 PM
camaro8tysvn
Feb 2, 2016 07:52 AM
bonesbrakr
Jan 26, 2016 06:50 PM
