Runs horrible with A/C on
Old Feb 16, 2016 | 08:22 PM
FormulasOnly's Avatar
Car: 1989 Formula 350
Axle/Gears: 3:23
1989 Formula 350 TPI This came on all of a sudden. If I turn on the A/C it will barely run... At forst I thought the compressor was seizing up but I don't hear any of the tell tale noises from the compressor.
Is there something that turns on that isnt?
Old Feb 16, 2016 | 08:27 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Runs horrible with A/C on
When you shift from park to drive, does the engine RPM lower slightly? If yes, suspect your idle motor might be the problem.
Old Feb 16, 2016 | 08:44 PM
Axle/Gears: 3:23
It runs and drives flawlessly other than the A/C. If I turn on the A/C at speed 1500rpm +, it starts bucking and lurching...
The more I think about it... It's probably the compressor.
Old Feb 16, 2016 | 08:45 PM
Axle/Gears: 3:23
I datalogged it and I can't find anything .... at idle or higher ...
Old Feb 17, 2016 | 02:42 PM
mrestrictrplate's Avatar
Car: 87 Iroc 5.7,67 SS Camaro,90 Formula
Engine: 355 AFR Superram LPE 219
Transmission: 700r4 3000 stall 4spd 5 spd
I've had a few cars that run rough stopped at a light with the ac on. I'm listening to this thread for the culprit.
Old Feb 17, 2016 | 05:48 PM
Axle/Gears: 3:23
Just did a thorough inspection of the belt. It's got about 3,000 miles on it and its fried cracked and looks like its got 103,000 miles on it... I'm 99.9% sure the compressor is starting to lock up or at least dragging hard.
Rob's z-28
Feb 21, 2016 01:32 PM
B4C5.7
Exterior Parts for Sale
Feb 20, 2016 07:27 PM
tognabologna87
Feb 17, 2016 04:46 AM
Night rider327
Feb 16, 2016 12:01 AM
Sichno
Feb 10, 2016 08:37 PM
