EGR Solenoid part 1
Old Feb 23, 2016 | 09:40 AM
bop11's Avatar
Car: 1988 GTA
Engine: VIN F 305 TPI
Transmission: AUto
EGR Solenoid part 1
We needed to replace the EGR solenoid on an 88 Firebird GTA with 305 F series engine. This solenoid has been out of production. Rock Auto listed a solenoid , AC Delco 214339 but it has some physical difference. Mainly the mounting and the electrical connector. Rock auto has a connector that will mate with this solenoid. However, the original connector in the car harness, has a very short lead and is tucked between the engine and the firewall. This would make cutting the old one off and crimping the new one very difficult. So after some research I asked AC Delco what would mate with the PT107 connector that is in the car. They said a PT134. When I questioned that both were listed as males in the catalog, I was told the PT134 was a female. So I bought a PT134 and a PT2830, mates to the new EGR solenoid, from Rock Auto. The PT134 turned out to be a male, however, the contacts are typical Molex contacts available at Radio Shack. I extracted the males from the PT134, connected the new Females to the bare ends of the PT2830, inserted them into the PT134 housing and now have an adapter cable.
Installation of the solenoid required a slight bend to the metal bracket and enlarging the hole in the base so I could mount it under one of the coil screws. It is important that the EGR valve is connected to the vented port on the solenoid. Note there is a filter on the back of the solenoid. If you attach a hose to one of the ports and with no power connected you can blow through it, that is the port that connects to the EGR valve. It allows for the vacuum in the line to the EGR valve to be vented when the solenoid closes letting the EGR valve close. Hook it up backwards and you will always have a vacuum leak.
One lead of the solenoid is always hot with the ignition on. The controller connects the other lead to ground in pulses to modulate how much the EGR valve is open. There is no EGR valve opening when the engine is cold, at idle or at WOT.
A copy of the ACDelco pigtail guide can be found online https://www.techconnectcanada.com/fi...d87cb52b9ce451
Old Feb 23, 2016 | 09:54 AM
bop11's Avatar
Car: 1988 GTA
Transmission: AUto
Re: EGR Solenoid part 1
old Solenoid
Female connections
New Solenoid
Male Connections
Old Feb 23, 2016 | 09:57 AM
bop11's Avatar
Car: 1988 GTA
Transmission: AUto
Pigtail in car male connection
PT134 is suppose to fit except it has male contacts
PT134 with male contacts removed
Old Feb 23, 2016 | 09:59 AM
bop11's Avatar
Car: 1988 GTA
Transmission: AUto
PT2830 to mate to new EGR solenoid
Female contacts inserted into PT-134 body.
New jumper with PT-2830 on one end and modified PT-134 on other.
Old Mar 24, 2016 | 06:17 AM
Saxondale's Avatar
Car: 84 Z
Thanks bop11. My car does not have this issue (as far as I know), but it is nice to see this information posted.
Old Mar 24, 2016 | 09:34 AM
chevypower91's Avatar
Car: 1991 Camaro Z28
Engine: 305 cid
Transmission: 5 speed
Axle/Gears: Posi/3:42
Bop11, very good write up. Does the existing wire on PT2830 have a female connection on the other that you had connected to PT134?
1Aauto
Sponsored Vendors
Oct 5, 2017 02:50 PM
1Aauto
Sponsored Vendors
Dec 12, 2016 10:43 AM
89 formula TPI
Feb 13, 2016 09:41 AM
ev305tpi
Feb 9, 2016 11:18 AM
89 350
Feb 2, 2016 09:46 PM
