CORVETTE PCV Hose (Passenger) 10055872 the same for Camaro?
Car: Custom 1992 Camaro Z28 25th Anniver
Engine: 5.7L V8 350 L98 TPI
I have a 1992 Camaro Z28 and the Crankcase Vent host is cracked and needing replacing. I found out through exploded part lists of the vehicle that the hose is GM: 10055872
I cannot find it anywhre online except for the CORVETTE one which is the same number (says 25" long). I've asked probably 10 places online that are selling them and have them instock for corvettes if this would work for a 1992 Camaro Z28 (which uses the same engine pretty much) even with the same GM part number... but they have all been unable to answer me a YES..
Does anyone happen to know? Afterall it is the same #... It's the 25" that I am unsure about...
Car: 88GTA
Engine: 5.7TPI
Re: CORVETTE PCV Hose (Passenger) 10055872 the same for Camaro?
Yes it works. You have to cut like 2 inches off one end. I bought one as others did. See this post
https://www.thirdgen.org/forums/tpi/...tion-tube.html
Engine: 4++,350 & 305 CIs
Looking at the pictures of one I'm sure it'll work but wont have the 100% correct routing
Whoboy580
Mar 4, 2016 07:10 PM
