Gotta brag~
Old Apr 15, 2016 | 02:20 PM
  #51
stephenscamaro's Avatar
Car: 1988 Camaro
Engine: 2.8 to 383
Re: Gotta brag~
Originally Posted by Tibo
Are you guys talking about my block? If so, I think you are noticing that I've had it machined to accept O rings. More common for boosting sbc. A properly done sleeve should almost be invisible. If they were that obvious to spot I'd want nothing to do with that block....
LOL I wasn't going to say anything rude when I initially thought it was sleeves. I was going to say I had never seen them done like that before
Would his mod be helpful for non-boosted engines?
Old Apr 15, 2016 | 05:25 PM
  #52
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Gotta brag~
Sure it would help for a non-boosted engine but it is totally unnecessary. Be akin to putting a full roll cage in a stock 300hp street car.
Old Apr 15, 2016 | 05:44 PM
  #53
Tibo's Avatar
Car: 1991 Z28 Vert
Re: Gotta brag~
Originally Posted by FireDemonSiC
I thought about that, however decided against the drilling. For what I'm doing, I found it unnecessary and just kept the mods basic. IE smoothing out the lifter valley, enlarging and radiusing drainbacks, .030 holes in the ghallery plugs. smoothed and ported the rear main cap and etc.
I used a Melling M55 standard volume pump with a 70psi relief spring. with 10w30 it holds around 25psi at idle woith a 180-200F oil temp.
I watched those videos when I was building my motor. Cool stuff they're doing, but the drilling wasn't really needed. My setup is hotter than what they built and I don't even need it.
M55 oil pump is all you need. Even using 5W-20 you'll still have ~25psi at idle. As an added point, there are several good articles advising for the use of 5W-20 for newly built engines.
Old Apr 20, 2016 | 11:11 AM
  #54
Car: 1988 Camaro
Engine: 2.8 to 383
Re: Gotta brag~
How far down should my pistons be in the bore if the deck was machined to 9.005?
Old Apr 20, 2016 | 12:57 PM
  #55
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Re: Gotta brag~
I didn't see in the thread if you are building a 350/355 or 383... The nominal height of crank+rods+piston in a SBC is 9.000" or 0.005" in the hole with a 9.005" deck height.
350: 3.480/2 = 1.740 + 5.700" rods + 1.560" compression height pistons = 9.000"
383: 3.750/2 = 1.875 + 5.700" rods + 1.425" pistons = 9.000"
383: 3.750/2 = 1.875 + 6.000" rods + 1.125" pistons = 9.000"
What pistons did you get? What are their compression height? Cheap rebuilder +0.030" "350" pistons are typically less than 1.560", open quench too far, drop compression, for a poor performing engine.
project89
Jun 13, 2008 09:48 PM
Stekman
Mar 15, 2005 11:09 AM
breathment
Aug 9, 2002 11:51 PM
breathment
Mar 26, 2002 12:20 AM
un4givin89
Mar 15, 2002 11:43 AM
