1990 RS Camaro wont start.
Old May 12, 2016 | 07:12 AM
Graphite07's Avatar
okay it has spark and fuel but it will not start. it cranks over just fine. it just died out and would not restart. i am thinking ignition control module?
any help thanks..
Old May 12, 2016 | 08:30 PM
armos's Avatar
Re: 1990 RS Camaro wont start.
Can you be precise about exactly what tests and checks you've done? You said it has spark, so if that's true even under failure conditions then it wouldn't be the ICM.
Is this a stock RS? Is it a 3.1L or a 305?
Old May 12, 2016 | 09:35 PM
Graphite07's Avatar
stock 3.1 V6 Rs. nothing done to it, well it had spark it made attemp to start. now it just cranks. i pulled the cap off the rotor turns over....... tried to start again i pulled the oil fill cap i do not see the lifter spring going up and down. its getting fuel
Old May 12, 2016 | 09:55 PM
tater's Avatar
Car: Dad's 87 Bird (Org Owner)
Engine: Vortec 350 Crate Motor
Transmission: TH350
Axle/Gears: 3.42 Posi
Try some starter fluid and let us know if it attempted to start.
John in RI
Mar 22, 2025 02:50 PM
someone972
Aug 9, 2017 03:29 AM
Fabrik_8
Classified Ads Feedback Board
May 9, 2016 10:33 PM
thomashearts
May 5, 2016 08:40 PM
J-money
May 5, 2016 03:22 PM
