Connecting rod press abor
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Does anyone know where to get these?
I know some guys use torches, and others even have rod heaters but I'd prefer to use my press to do pistons.
-- Joe
-- Joe
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Connecting rod press abor
I really want to get the right fixture so I can do it like the dealer does.
-- Joe
Pressing a wrist pin out - YouTube
-- Joe
-- Joe
Does not get used much as most of my builds are floaters.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
As mentioned in the video, if you need to keep the pistons then you need some sort of jig to hold the con rod while pressing out the wrist pins. If you're not keeping the pistons then it doesn't matter. Place the piston right on the press and push out the pin.
When installing wrist pins however, the rod needs to be heated so the small end will expand to allow the wrist pin to slide through it. If you try pressing in a wrist pin cold, you will probably damage the piston.
Floating pistons is the best way to do it. No special tools required other than a small screwdriver.
For the cost of tooling, time and effort to press in and out wrist pins, it can probably be cheaper to just have a machine shop do it.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
The idea is the fixture holds the ROD, so no pressure is placed on the piston at all.
I've got lots of "X" rods and forged pistons lying around that I'd like to use eventually. The local machine shop isn't local, and gets $25 per rod to do the job.
-- Joe
jeremy iroc z28
Oct 25, 2016 03:03 AM
