help wont start
Old Dec 25, 2001 | 11:37 PM
STROKINV8's Avatar
help wont start
87 formula 350 tpi ,,,,was driving hit a bump,,,car died ,,,like just quit running,,,towed home,,,,checked fuel pressure at the rail 48 lbs,,when ya turn the key on,,,,checked fire,,,bridges a big gap on my tester,,,just in case did change out the module in the distributer,,,no luck ran the codes i get first 12 ,,,15, ,22,,34,,42
15 is low temp at coolant temp switch,,22 low voltage at tps,,,or fuel cuttoff relay circuit open or shorted to ground,,34 low voltage (high vacumn) at mass airflow sensor or map sensor,,42 fault at electronic spark timing or fault at direct ignition system,,or faultat fuel cut off relay circuit,,and y help would be greta and where is the fuel cutoff relay when i crank it the fuel pres is at 48 while cranking it goes to 42,,then after bout 20 secs is starts ta go down,,but it never starts
any help would be great
Old Dec 25, 2001 | 11:51 PM
rezinn's Avatar
I was driving home on the freeway once, going 115 up a ramp(no one was anywhere near, it was a toll road) and my car stalled and wouldn't start. I checked for codes and got a 22, I remembered that had something to do with the timing circuit so I checked the distributor connections and one had fallen off of the ignition coil. Check for that.
Old Dec 26, 2001 | 12:18 AM
STROKINV8's Avatar
swapped out module,,,wires ok,,,and didnt help
Old Dec 26, 2001 | 11:36 PM
buickman's Avatar
have you by chance checked your fuses? you've probably got a fuse for Inj. or Ecm-a or ecm-b. start there.
Old Dec 27, 2001 | 12:13 AM
STROKINV8's Avatar
turned out when i hit the bump my wire connecter on my ecm fell out i guess it was not plugged all the way in,,,runs again
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
