HELP At a loss
Old Dec 26, 2001 | 11:08 AM
RScamaro39's Avatar
HELP At a loss
My problem is a idle miss and hesitation/sluggish performance while driving. The idle miss becomes bad when I take the RPM's up to around 1000 and when driving at take off and afterwards I get sputering no performance and sometimes i hear what sounds like a intake backfire (Only when I push hard on the pedal). I have replaced or checked the following parts.
92 RS 3.1L 5 Spd Man
Distriubutor (Persision Tune Recommended) here after known as (PT)
Alternator (PT) Said bad diode
Cap/ Rotor
O2 sensor
MAP checked
Fuel Filter
Added B12 Injector cleaner
Gas line dryer
IAS Checked
TPS Swaped
EGR checked
Bosch wires (5 months old) no crack detected
AC RapidFires (5 months old)
Have reset and rechecked timing and firing order
Any Ideas?
Old Dec 26, 2001 | 11:21 AM
Dave's 89's Avatar
Car: 89 IROC-Z
Axle/Gears: 4th Gen/3.42
Sounds like a fuel delivery problem.....Have you visually inspected the injectors while the car is running?
Old Dec 26, 2001 | 11:23 AM
RScamaro39's Avatar
I have true FJ (fuelrails) can I do this?
Old Dec 26, 2001 | 11:37 AM
Dave's 89's Avatar
Car: 89 IROC-Z
N/M....I was under the impression you had a tbi setup.
RedLeader289
May 28, 2019 01:47 PM
Elephantismo
Feb 13, 2019 12:51 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
3.8TransAM
Sep 27, 2015 08:37 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
