Cold weather: how much extra hp?
Old Dec 26, 2001 | 01:44 PM
3.1 firebird's Avatar
Does anyone know how much extra hp your car is making when he weather getsa bit below the freezing point, compared to say a 75 degree day?
Old Dec 26, 2001 | 02:15 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
I knew this a while back but forgot. Reg, Im 90% sure its 1hp for every 5* drop.
SSC
Old Dec 26, 2001 | 02:45 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
I can not tell you the exact number but I can tell a big difference in performance when the temp is like -10C compared to like +5c.
If I had to pick a number it would be 20 to30hp. I know some people might laugh at it but I actually have been watching the chnege in temp/air and getting out there and testing the car. I have no real numbers or 1/4 timesbut from my experience it make a very big difference if your car is properly tuned.
My TPI responds very well to colder/denser air. There was an earlier article about the "Limits of the TPI" and someone there has all the numbers and times to prove this theory. On a colder night their TPI made a 1/4 mile pass one second quicker than on a warmer day. And they have done this pass several times to prove this.
Anyway, that is what I noticed about my car.
Old Dec 26, 2001 | 05:36 PM
Damon's Avatar
The old rule of thumb is 1% for every 11*F.
Old Dec 26, 2001 | 05:38 PM
Damon's Avatar
...............if the carb is jetted properly to compenste for the change in A/F ratio due to the change in temp. You'll want to change approx. 1 jet size for every 40* change in temp on most commonly available performance carbs. Colder you need to go richer, lener when you go hotter.
Old Dec 26, 2001 | 09:35 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
just to give you a point of reference
I ran my daily driver on the mti dynojet in Feb 00. The printout indicated a correction factor of .97 and an inlet airtemp of 65.5 degrees (I remember it was rainy). To my understanding thats 3percent high there just based on the cooler temp.
All i know is the tires dont hookup too well when its cold.
RS Reaper
Oct 17, 2018 07:52 PM
mattcanty
Oct 12, 2015 11:08 AM
loud91rs
Oct 5, 2015 10:05 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
mfp189
Sep 27, 2015 09:25 AM
