Oil Pan
Old Jul 4, 2016 | 05:25 PM
Nighthawkf-117's Avatar
Car: 91' Camaro RS
Engine: 305 TBI V8
Transmission: 700/R4
Axle/Gears: Stock
Oil Pan
Rebuilding my engine and at some point in its like someone dented/punctured then welded the oil pan. Figured i might as well replace it while the engine is out. Looking on summit alot of the options got poor reviews, just looking for a standard replacement.
Any recommended brands/products?
Old Jul 5, 2016 | 04:07 PM
cardo0's Avatar
Car: Fourth Gen '94 camaro
Engine: 350 Gen II
Transmission: A4
Re: Oil Pan
For just a stock replacement try Rock Auto. They have several that look good like the Pioneer and even the Dorman (only $37).
Unless u really know u need better just replace with a stock pan. Performance oil pans will just cost you more not provide any benefit for a daily driver.
Old Jul 5, 2016 | 07:21 PM
Re: Oil Pan
That's prolly the most common-sensical thing to do; just yerbasic stock replacement.
Check Summit, Amazon, etc. as well for a good quality part at a good price. Don't go with "the cheeeeeeepest you can find". Pioneer and Dorman are 2 reliable names to consider; there's plenty more.
Old Jul 6, 2016 | 08:34 PM
Car: 91' Camaro RS
Engine: 305 TBI V8
Axle/Gears: Stock
Re: Oil Pan
I see alot of 4 quart pans listed under rock auto for my car. Is there any disadvantage to going with a 4 quart pan?
Old Jul 7, 2016 | 07:03 AM
Re: Oil Pan
That's what your stock one was/is.
Old Jul 7, 2016 | 11:47 PM
Car: 91' Camaro RS
Engine: 305 TBI V8
Axle/Gears: Stock
Re: Oil Pan
So i assume the reason the engine takes 5 quarts of oil is because the pan its self holds 4 quarts and the extra quart is distributed through the oil passages and other areas of the engine?
Old Jul 8, 2016 | 06:34 AM
Re: Oil Pan
Filter mostly.
Old Jul 8, 2016 | 06:42 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Oil Pan
Best thing I have done is to look on Ebay for take off pans from boats. I just picked up one from FL for 25 shipped.
Old Jul 9, 2016 | 11:51 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Oil Pan
I bought a stock looking oil pan that was 5 quart capacity with a small windage tray. It worked well but I upgraded to a better pan for my 383. I still have that 5 quart oil pan with a rubber seal (both in excellent condition) for a one piece rear main engine. PM me if interested, I've been meaning to sell it.
Pretty sure this is the one I use now : https://www.summitracing.com/parts/sum-g3603/overview/
This is the one I had used: https://www.summitracing.com/parts/sum-g3503b/overview/
Mikes86transam
Oct 25, 2016 11:50 AM
David Fite
May 9, 2016 09:58 PM
Mattkovitch
May 1, 2016 11:03 PM
astout82
Apr 28, 2016 10:11 PM
Redvert88
Southern California Area
Apr 6, 2016 11:29 AM
