AC leak, maybe
Old Aug 1, 2016 | 12:57 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
AC leak, maybe
Where is the most likely spot that an AC will leak?
The car (92 Z28) was converted to 134A. It was doing great for a month, but then after I finished hooking up the fan controller, the compressor started to cycle. So I hooked up my guages.
Engine off, 85 low side 75 high side. Compressor on, dipped down to 20/150.
I added about 20 ounces of a left over bottle i had. He jumped to about 25/190 compressor on. 20 ounces seems like a lot for such a small increase.
Old Aug 1, 2016 | 01:53 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: AC leak, maybe
Possible leak locations.
Evaporator inside heater box
Any rubber part of a hose or where the metal crimps around the rubber hose
Any o-ring/seal connection where a hose connects to another component
AC compressor (body joints, shaft seal etc)
You could use a freon sniffer to try and pinpoint a leak. When I repair ac systems, with all the freon out of the system, I charge the system with nitrogen then use a soapy water solution to spray all possible leak locations and look for bubbles but even then leaks at the evaporator can't be seen. A freon sniffer at a dash vent can usually detect a leak from there.
Old Aug 1, 2016 | 02:54 PM
irocman7's Avatar
Car: 89' Sunset Metallic Orange Iroc-Z
Engine: Forged 383
Transmission: TR6060
Axle/Gears: 4.11 9 inch
Re: AC leak, maybe
I agree with above. Mine always seemed to leak in the compressor body with the R4 compressors, or the sides of the condenser.
I know it's not recommended, because it supposedly adds contaminates into the system, but if it's totally empty I have added 80 psi of shop air into the system then sprayed everything with dish soap and water mixture and look for bubbles. I guess you could try it without the shop air and see if the freon will make bubbles.
Old Aug 2, 2016 | 04:13 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Re: AC leak, maybe
Here are a few pics of the dye. The first is behind the compressor, and the other 2 on the dryer.
The dryer might be normal. I bet people in the past didnt cover up the connector when plugging/unplugging, and stuff just went everywhere.
I dunno if whats running down the compressor is normal though.
I dont know how to get access to the condenser. Its pretty crowded down there.
Attached Thumbnails AC leak, maybe-img_0026.jpg   AC leak, maybe-img_0027.jpg   AC leak, maybe-img_0028.jpg
propaintball96
Apr 12, 2016 01:30 PM
stegal
Apr 6, 2016 03:33 PM
89TA WS6
Apr 1, 2016 09:40 PM
Steve
Southern California Area
Mar 28, 2016 10:09 PM
89convertIROCer
Aftermarket Product Review
Mar 31, 2001 08:04 PM
