Complete ignition system overhaul 305 LG4
Car: 1985 Pontiac Firebird Trans Am
Engine: 305 LG4
Transmission: 700R4 Automagic
Axle/Gears: No clue
As the title suggests, I'm thinking my next project will be a complete ignition system overhaul for my 1985 Trans Am LG4...the only problem is I'm not sure exactly what parts I should get in order to do that. I don't want something for super extreme performance, I just want something reliable. My plan is for this car to be a good daily driver and make the LG4 the best it can be until I can afford a complete engine/transmission swap in the distant future. So any suggestions and advice would be very appreciated!
Engine: 305 LG4
Axle/Gears: No clue
Re: Complete ignition system overhaul 305 LG4
I guess what I'm asking is what type of distributor I need to buy, and if I buy a complete distributor what else would I need besides the plugs and wires? I've tried doing some research but I can't really find any straight answers...
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
You do not need a new distributor. If you do, it will be a cheap Chinese with soft plastic parts.
Just buy a good quality Standard Motor Products DR450 cap and DR318 rotor. Get a good quality OE style wire set as well.
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
I would replace the distributor. I've replaced a few of the large cap distributors over the years with re-man units with no problems. The replacement dist will come with a new pickup coil and ICM. Replace the coil, cap and rotor at the same time.
Add wires and plugs and everything will be new. No need for the more expensive aftermarket pieces on a standard LG4.
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
MantyZ28
Apr 11, 2016 12:04 AM
theformula
Aftermarket Product Review
Oct 16, 2000 06:49 PM
