Distributor Gear
Old Aug 5, 2016 | 08:35 PM
Flip33's Avatar
Car: 1933 Ford Sedan, 1934 Ford Pickup
Engine: 350 Chevy
Transmission: 700 r 4
Distributor Gear
I am in the process of converting a L-31 to a carb. I will be using a MSD 8360 distributor. I believe I need a melonized gear for this motor. Not sure my MSD has that gear. Can I use gear from my original dizzy or is GM the best source for this gear? Any way to tell if my MSD has melonzied gear?
Old Aug 8, 2016 | 11:52 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: Distributor Gear
Unless somebody messed with it, that MSD distributor should have a standard iron gear, which is perfectly compatible with either the stock GM L31 cam or any cast (non-billet core) cam.
Your original dizzy gear, if it's not worn, would be fine too.
Old Aug 8, 2016 | 12:36 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
That MSD distributor should come with MSD PART# 8531 pre installed which is a Melonite QPQ coated gear
seanof30306
Jun 25, 2016 10:49 AM
1992Vortec
Jun 14, 2016 07:25 PM
gsonor
Exterior Parts for Sale
Jun 12, 2016 08:16 AM
dpmalibu
Jun 4, 2016 09:07 AM
NotMark
Jun 2, 2016 08:42 PM
