stroker question
Old Aug 5, 2016 | 10:45 PM
bensbaby's Avatar
Car: 1988 GTA Trans am 1 owner since new
Engine: 383 built
Transmission: 1995 camaro t56 6 speed
Axle/Gears: 3.24 posi 9 bolt
stroker question
Is it possible to build a 305 tpi 1988 gta centerbolt into a stroker?
Old Aug 6, 2016 | 01:51 PM
Re: stroker question
Sort of...
You can spend twice as much on that as a 350 would cost, and get a 334. Basically a good way to waste a bunch of money and not get something better that you could have gotten by spending ALOT less.
Old Aug 7, 2016 | 10:57 AM
bensbaby's Avatar
Engine: 383 built
ok ty
so just get a 350 and do it
Old Aug 7, 2016 | 01:06 PM
Yup; that's about it.
Or, you could stroke THAT, and get AWHOLEHELLUVALOT more than you can ever get out of any 305.
Old Aug 7, 2016 | 05:55 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The small bore of the 305 doesn't make it economical to stroke unless you need a smaller engine for something. Just dropping in a 350 is better than stroking a 305. Cost is the same to make a 350 into a 383 as it is to make a 305 into a 334. Short of finding or buying a 350, it's more cost effective to find a 350 to use. Chances are you can probably buy an already built 383 for not much more than what you would have to do to buy a 350 and build one. Even places like Jegs and Summit have 383 short and long blocks in street specs so all the machine shop work is already completed.
Old Aug 7, 2016 | 06:22 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Agreed. It's cheaper to buy a bare block prepped for a 383 build than it is to buy a used block and have it machined. But then depending on your abilities and used parts hook ups swapping to LS based may be the same amount.
86ZRESTO
May 21, 2018 08:33 AM
Pilotrick50
Jun 14, 2016 10:08 AM
Pilotrick50
Apr 11, 2016 08:55 AM
Spenc247
Apr 3, 2016 03:09 PM
IROC AND ROLL
Mar 29, 2016 09:52 AM
