Engine Idle/ Stalls
Old Aug 10, 2016 | 07:26 PM
windsorman707's Avatar
Car: 1991 Camaro Z28 Convertable
Engine Idle/ Stalls
Hello all 3rd gen camaro fans. This is my first post as I am new to this.
I have a 1991 camaro Z28 convertible, 5.0 MPI that I have owned since 1993.
My problem is, all of a sudden, the car is hard to start. when it does start,it idles. if I press on the accelerator the rev goes up a few rpms then stalls. I will do that a few times and then it wont start at all. after a couple of days I can start the procedures allover again. Hopefully someone has had the same problem and could help me out. It would be most appreciated. I hooked up a scanner/code reader and it showed NO codes.
Thanks,
Michael
Old Aug 12, 2016 | 10:56 PM
maks10's Avatar
Car: 1990 Trans Am
Engine: 5.7 350 HSR afr195 xfi268
Axle/Gears: 3.08 posi
Re: Engine Idle/ Stalls
Probably need to know if your timing and fuel pressure have been checked? Anything changed or added before this started?
Old Aug 13, 2016 | 10:36 AM
Nothing has been changed. It just started having that problem. I can hear the fuel pump prime. Ill have to check the fuel pressure.
Thanks for your input.
Michael
89irocz355
Mar 28, 2018 08:24 PM
89irocz355
26
Sep 12, 2016 01:28 PM
89irocz355
Exterior Parts for Sale
18
Apr 11, 2016 10:17 PM
'91CamaroRS
Mar 29, 2016 06:42 PM
Matthew1
Mar 18, 2016 02:40 PM
