Do I need to do a hot valve lash adjustment?
Old Aug 10, 2016 | 10:10 PM
mikeyt's Avatar
Car: 92 Camaro
Axle/Gears: stock
92rs 305. Just finished putting Vortec heads on it and all new top end parts to go along with it. Haynes manual says to take lash out then go 3/4 of a turn. I took the lash out and went 5/8 of a turn because I wasn't sure of how the valves in the Vortec heads would seat and may collapse the lifters and not get compression, I wanted to give plenty of room for thermal expansion. I started the car and it ran great, no noise in the valve train at all, then I shut it down after I checked for leaks since I only put water in it. Tomorrow I'll drain it, refill with antifreeze, however should I run it and tighten those rockers the other 1/8 of a turn while running or should I go back through the original procedure as prescribed in the book and reset them, or just leave it alone?
Old Aug 11, 2016 | 07:14 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: Do I need to do a hot valve lash adjustment?
Leave it alone.
There's no reason to do a hot lash adjustment with hydraulic lifters as long as you do the cold static procedure correctly. and it sounds like you did.
skinny z's Avatar
It should be fine as it is.
You have the self guiding rockers for the Vortec heads heads?
Old Aug 11, 2016 | 07:33 PM
mikeyt's Avatar
Car: 92 Camaro
Axle/Gears: stock
Ok guys, thanks. I know I gave it a little wiggle room to be sure. I rechecked my rockers today prior to securing the valve covers and they had the slightest of movement, nothing out of the ordinary.
89irocz355
Mar 28, 2018 08:24 PM
89irocz355
26
Sep 12, 2016 01:28 PM
BG1959
Jul 20, 2016 02:22 PM
89irocz355
Exterior Parts for Sale
18
Apr 11, 2016 10:17 PM
89irocz355
Mar 27, 2016 09:52 AM
