Choke Heater/Fuse Help!!!
Old Dec 27, 2001 | 05:29 PM
nates's Avatar
k, i need to check my choke heater fuse on my 87 camaro z28 (carb'd) cause i'm reving really high, so high that my car wont even turn off, but when i go to my fuse box, it is totally different from my manual. the manual says in position 4 there should be a 20 amp fuse for the choke heater, but on my actual fuse box, position 4 is something else....the only thing that resembles something to do with the chock heater on my actual fuse box is in position 6, and its "c/h inj" but it is a 15 amp fuse...shouldnt the choke heater fuse be 20? anyone have any idea what is going on?
Old Dec 27, 2001 | 06:04 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It should be a 20 amp fuse at the "top right" of the fuse box. With the box in the car under the dash, this is the fuse closest to you at the right.
If your choke heater fuse is bad, your choke light should be on or glowing dimly, and you may hear the choke relay buzzing under the dash.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Saxondale
Carburetors
33
Oct 1, 2015 10:26 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
