Aftermarket shafts
Old Aug 24, 2016 | 07:05 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
Aftermarket shafts
Im just looking at all options to improve steering (not including the astro/jeep shafts). Apparently there are other companies that make shafts, although somewhat expensive. Has anyone used something like this
Old Aug 27, 2016 | 08:33 AM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Re: Aftermarket shafts
If you're having steering slop, and have replaced the rag joint and adjusted the steering box itself, plus have replaced all the tie rod ends, both inners and both outers, with new aftermarket adjuster sleeves, and have replaced the idler arm and the center drag link, then the Astro / Jeep shafts will solve anything remaining.
I did the Jeep shaft to my '87 S-10 to clear my V8 swap. The improvement was barely noticeable, and may have been the placebo effect, but it gave more header clearance.
Drew
Aug 11, 2018 03:26 PM
Out-Cast
Sep 15, 2016 04:09 PM
ChevyKen
Interior Parts Wanted
Sep 11, 2016 08:52 AM
NiG
Aug 22, 2016 12:20 PM
joker_86z28
Aug 16, 2016 04:05 PM
