Throttle body and IAC
Old Aug 31, 2016 | 09:28 PM
Rls4762's Avatar
The IAC is supposed to unscrew from the throttle body like a spark plug correct? Mine will not budge for anything.
I'm also concerned about the two missing screw heads on top, looks like they snapped off. Should I just replace this whole assembly? I can get a TB and IAC used for fifty bucks.
The black piece sticking out in my hand is the IAC correct? This is off a 305 TPI
Old Sep 1, 2016 | 09:44 AM
Drew's Avatar
Re: Throttle body and IAC
Yes that's the IAC and it just spins out. They're generally good and stuck, pretty sure the assembly line used a thread sealer to prevent leaks that tends to lock them in place. Carefully clamp the throttlebody in a bench vice and use a large wrench that fits properly and they usually come loose. Light heat would probably help too.
There's no reason to believe that a used throttlebody is going to be in much better condition.
Old Sep 2, 2016 | 12:36 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I use PB Blaster on almost anything that is threaded and wont budge with moderate pressure.
The only time I really crank on it is after the blaster has been applied.
That rarely happens.
Spray just a little where the threads start and give it an hour.
PB Blaster should be in ever ones tool shed.
86ZRESTO
May 21, 2018 08:33 AM
Pilotrick50
Jun 14, 2016 10:08 AM
Pilotrick50
Apr 11, 2016 08:55 AM
IROC AND ROLL
Mar 29, 2016 09:52 AM
theformula
Aftermarket Product Review
Dec 1, 2000 08:03 PM
