loose wire
Old Aug 31, 2016 | 10:09 PM
T-IROC87's Avatar
loose wire
87 irocz v8 305 tpi
The wire appears to have the connector broken off , but Where does it connect to?
Pic 1
Pic 2
Old Aug 31, 2016 | 11:13 PM
Drew's Avatar
Re: loose wire
Looks like it probably goes to the fan switch. Note the switch between the plug wires in the first pic.
Old Aug 31, 2016 | 11:51 PM
T-IROC87's Avatar
Re: loose wire
Where does it plug into and how do I replace it? Any part #s?
Old Sep 1, 2016 | 08:33 AM
Drew's Avatar
Re: loose wire
It plugs into the only open sensor in your photos. The fan switch is between the #6 and #8 spark plugs, can't miss it. The wire is missing the plastic shell that would snap onto the fan switch, it'd look just like the plastic shell on the knock sensor which is visible in the second photo next to the starter. Search for a fan switch pigtail at your favorite auto parts website. Should be able to just remove the plastic shell from the pigtail and snap it onto the existing terminal.
Old Sep 1, 2016 | 09:45 AM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
Re: loose wire
Visual of what drew explained:
connector you will need:
http://www.ebay.com/itm/like/311674922470?lpid=82&chn=ps&ul_noapp=true
Old Sep 1, 2016 | 02:30 PM
T-IROC87's Avatar
Re: loose wire
Ok thx I found it! ordered at NAPA Standard part # S-550 thx drew!!
Old Sep 1, 2016 | 02:31 PM
T-IROC87's Avatar
Re: loose wire
Camaro Firebird 90 92 TPI Cooling Fan Switch Connector Pigtail | eBay
Thx batman!!
Podium
Exterior Parts for Sale
Feb 18, 2013 02:02 PM
327_TPI_77_Maro
Classified Ads Feedback Board
23
Dec 10, 2009 08:50 PM
