what rear have i?
Old Dec 27, 2001 | 11:56 PM
86-red_dawg's Avatar
what rear have i?
i have an 86 lg4 sport coupe auto (700r4)
i know my rear ratio is a 2.73, but what type of rear have i?
i'm looking to install a new set of 3.73's without changing out the whole rear, and need some info to do research
thanks
Joshua
Old Dec 28, 2001 | 01:13 AM
Momar's Avatar
If they are 2.73s it is a 10 bolt. If you have posi already you can just get the gears you want for a series 2 carrier, but if you dont have posi, you might want to look into a posi carrier. The one you have now is series 2. It normaly only supports up to 3.08 gears, but you can get gears for the series 2 that are 3.23 and higher (numberically). If you want to do this I think that they sell them in jegs or summit. Make sure you get your stuff for the 7.5 ten bolt with 26 spline axles. You can upgrad to 28 spline axles, but it does not sound like you want to spend that much money.
Ben
Old Dec 28, 2001 | 10:47 AM
ok, i don't have posi and am not interested in upgrading to posi at this time - so lemme get this straight - i need to upgrade my carrier? or i can get special gears for my series 2?
after i get load of money and more time to spend working on my car i plan on not only replacing the whole rear with a posi disc 3.73 from a newer camaro, but also attempting a t56 install as well, but for right now i'd like to get a little bit more oomph
thanks
Old Dec 28, 2001 | 01:48 PM
Damon's Avatar
First off, count the number of bolts around the rear diff cover. If it's got 9 bolts its a............... well, um, a 9 bolt rear, obviously. If it's got 10 it's............ you get the idea.
You can get special gears for the 10 bolt that will let you put in 3.08 or numerically higher gears on a 2-series carrier. The ring gear is thicker.
On a 9 bolt you're S.O.L.
Old Dec 29, 2001 | 10:45 AM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
An LG4 camaro only came with the 10 bolt rear. in 86, an LG4 would have the upgraded 7 5/8 ring gear. they do make a 3.73 gear that will fit on your 2 series carrier, yes. just make sure to request that.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
