Camshafts
Old Dec 28, 2001 | 10:14 AM
BuddyLeeX's Avatar
Car: 06 Toyota Tundra SR5
Camshafts
ok comp camps are teh best, I saw one on ebay that is a 262h grand and I want it but I dont think I will have the dough to get it since Im getting headers and y-pipe. With headers, and no other engine modifications, will this camshaft work for me, if not will it work with 1.6 ratio roller rockers and an edelbrock intake?
Lift: .465/.488
Duration: .224/.234
Rpm Range: 2500-6000
The degree is 109 for intake and 119 for exhaust
This too big? Or will it be ok with rockers, headers and intake?
Old Dec 28, 2001 | 10:31 AM
Joshua Leslie's Avatar
yah, id say thats a bit much for a 305, at least on the duration side of things.
Besides, if the engine/drivetrain is otherwise, stock, y would you want a cam that didnt start making power until 2500rpm? it will be a total dog off the line. Also, since its not really a great idea to run a stock motor to 6000rpm, thats more reason not to get that cam.
also, dont buy a used cam.
for the 305, I would say get a comp cams x/e 252 or a 262.
I dont know what the comp cams "H" is that u described, but the x/e 262 makes power from 1200-5600rpm.
I would say get the edelbrock performer intake, the RPM will not fit under the stock hood, go with the x//e 262 cam, a set of headers, and ur car will haul ***.
Remember, the cam will only work good if the rest of the car(rear end, engine rpm, car weight, gearing, stall speed) is matched to it.
Old Dec 28, 2001 | 10:34 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I think it's too much cam with 2.73's and a stock torque converter, without mentioning heads and exhaust.
What you should do is call Comps 800 number techline and get some suggestions.
Old Dec 28, 2001 | 12:02 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
cam rule number 1 - any duration over about 218 needs converter/gear
Not much gear, 3.42 to start.
Thats on a 350. A 305 should not go over about 214.
Old Dec 28, 2001 | 01:52 PM
Damon's Avatar
I'tll work fine. It will make good power jsut about at the stall speed of a stock converter.
Old Dec 28, 2001 | 02:25 PM
GRENDLE's Avatar
uh yeah, sure , it's a step too big for your 305. and the 1.6 rockers will only make things worse. your lift will end up at like 488/502. the comp extreme energy they recomend is like 443/465 lift with 214/214 duration @.5 with a 112 centerline. it's a special grind for tpi 305's and 350's
Old Dec 28, 2001 | 04:41 PM
BuddyLeeX's Avatar
what about the comp cam XE262h grind?
Old Dec 28, 2001 | 05:05 PM
yeah, that would be a good choice, even the x/e 256 would be good.
The x/e 262 may have to much lift for your stock valve springs, and could cause valve float at high rpm.
its always a good idea to go to small than to big with a cam
Old Dec 28, 2001 | 06:36 PM
iroc5speed's Avatar
oh come on, you can't be serious. It fit under my hood. I had a 3"drop base open element air cleaner with a 1/2 inch spacer that raised the air cleaner. It fit just fine.
Old Dec 29, 2001 | 10:51 AM
dont know how that is, I only have the Perfomer manifold and my air cleaner(low profile edelbrock, only about 1 inch high) hits the top of my hood.
I tried the rpm and when I put the carb. on, could barely shut the hood, thats with no air cleaner.
Bubbajones_ya
Jul 6, 2024 08:32 PM
db057
Apr 28, 2019 07:45 AM
PurelyPMD
May 5, 2016 04:57 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
GTAman
Sep 26, 2015 02:01 PM
