sbc 327 wants to stall
Car: 1982 z28 camaro
Engine: 327
Transmission: borg warner super t10
i have a sbc 327 with a holley 600cfm carb , im thinking it is a carb problem but have tried tuning it and cant fix it . the car wants to die when releasing the clutch , but if im really easy on the gas i can get it going. after the cars moving it runs god and purrs like a kitten.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: sbc 327 wants to stall
What have you tried to fix it?
Did it sit for a while?
Assuming the carb isn't defective, try a higher # power valve.
See the Holley Tuning sticky on the carb forum.
Engine: 327
the car ran great when i bought it a year ago , i have set the float level and tried adjusting idle screw mixture but it doesnt seem to effect the car at all when i adjust it .
So how did following the instructions in the sticky, start to finish, in order, skipping none, work out for you?
padak
79
Aug 11, 2017 08:03 AM
Ozz1967
Sep 17, 2016 08:17 AM
