sensors on 85 lg4
sensors on 85 lg4
I have an 85 T/A with an lg4 and am changing motors but sticking with the ccc. I was wondering what are all of the sensors because I want to replace them all. I have heard that I should use a different knock sensor for a 350. Can I use the one from the tpi's? Thanks for your help and if possible I need this soon.
Ben
Ben
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Let me see,
you have a knock sensor, Baro Sensor, Map Sensor, O2 sensor, Coolant temp Sensor, Coolant Temp Switch, ESC Module, Oil Pressure Sender, and I think that might be all of them.
I took almost all of the computer controlled sesnors off in the summer of 2000 when I went to an Edelbrock Carb, Intake setup, and those are all I can remember off the top of my head.
I just recently swapped to TPI, what a PITA.
What is the difference between the baro sensor and the map sensor? I just went to the parts store and looked at them and the only difference I saw was the colors of the plugs (green and blue) I know my car has the green one. (map sensor) but what does the baro sensor do and where is it?
HoosierinWA
Oct 7, 2015 10:15 AM
