distributor still moving after being tightin... any suggestions
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
Re: distributor still moving after being tightin... any suggestions
The hold-down bolt may be bottoming out in the threaded hole in the manifold. Try putting a washer or two under the bolt and tightening again to see if it makes a difference.
Car: 1984 Z28 HO
I have heard the fancy cheap aluminum hold down brackets will bend and not hold it tight.
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
I replaced my bolt with a stud. This way the stud is fully engaged and I use a washer and flanged nut. Makes getting everything started much easier.
