6 way power seat just stopped working-help
Old Sep 27, 2016 | 01:53 PM
Roblen91GTA's Avatar
Car: 1991 Trans am GTA
Hey so my power seat just stopped working in my 1991 camaro z/28 and i did some testing and the orange wire gets 12 volts, and i get 12 volts to the back of the switch so i just replaced the seat switch on impulse and that didn't fix it, i also figured theres no way all of the motors died at the same time.
Any insight would be great, thanks
Old Sep 27, 2016 | 03:44 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: 6 way power seat just stopped working-help
Here's some diagnoses tips
Old Sep 27, 2016 | 09:56 PM
Thanks, i'll do some more testing based off that and see what happens
Old Sep 27, 2016 | 11:15 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Id check the circuit breaker in the fuse box.
Old Sep 28, 2016 | 12:04 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Since you already know that your getting power,... Check the ground. It might be rusty or loose.
Old Sep 28, 2016 | 12:53 PM
I checked the circuit breaker by swapping it with a 30 amp fuse and still nothing.
Is the ground under the carpet?
Old Sep 28, 2016 | 01:01 PM
mantaguy's Avatar
Engine: 5.0 EFI
Yes it is
Old Sep 28, 2016 | 02:02 PM
Ok thanks i'll check that
Old Sep 28, 2016 | 06:43 PM
John in RI's Avatar
Don't dig under the carpet right away....... Rather than trying to access the ground wire itself (where it's bolted to the body under the rug), just "JUMP" the black wire @ the plug with a proven-good ground.
OR
Use a 2 wire test light. @ the plug simply JUMP the ORANGE with POS and the Black with NEG and the light should work 'at all times'.
If you have good Power and Ground at all times then next things I'd do is inspect the Switches' Plug itself. I've seen a couple seat harnesses that had corrosion on the round-type plug terminals before. I'm guessing that a needle or thin wire would be about the only thing that might be able get into all those little holes to "scratch" the terminal clean enough again to make a complete circuit.
Do you KNOW the replacement Switch is functional ? (I doubt it's the switch ) It's not a bad Idea to use a small wire brush on the terminals on the back of the switch itself to be sure they are all clean.
Like you; I find it hard to believe that all 3 motors just failed !
Old Sep 28, 2016 | 09:42 PM
Ok so i didn't start looking for the ground under the carpet but i was looking for a cut wire or corrosion on the pins where the switch goes and they are all clean. with my voltmeter i back probed the switch at the black and orange wire and they get 12 volts but on the new switch if i depress the up and down it drops to 0 volts but side to side stays at 12. the old switch it drops to 0 volts in all directions i thought that was strange.
The only other thing that i know is the seat worked up until i had to unbolt the front two bolts and gently pop a wheelie with the seat to get a center console bolt i dropped into no mans land.
Old Oct 3, 2016 | 12:45 PM
found the problem, the part where the pins on the back of the switch make contact had to be pinched tighter to make better contact and i totally over looked that. thanks for the help guys
Old Oct 3, 2016 | 07:13 PM
mantaguy's Avatar
Engine: 5.0 EFI
1Aauto
Sponsored Vendors
Sep 21, 2016 03:19 PM
Marcus166
Aug 18, 2016 11:35 AM
jstanfi1
Aug 15, 2016 11:27 PM
86IROC112
Aug 8, 2016 09:43 AM
LDR
Aug 7, 2016 09:30 PM
