Rear View Mirror Button Won't Hold
Old Oct 4, 2016 | 12:30 PM
Vinscully50's Avatar
Car: 1986 Camaro IROC Z
Engine: LB9 305 TPI
I am really frustrated right now. I cannot for the life of me get my rear view mirror button to stick to my windshield. I clean the old glue off of the windshield, clean the windoshield, give it a few minutes to dry, scrape off the glue from the button and then apply the new glue. As soon as I stick the button to the windshield, it won't stick. All it does is slide around. I held it in place to the length of Master of Puppets and as soon as I take my hand away it falls down!
I've gone through 3 different mirror kits and the last one just now!
Old Oct 4, 2016 | 01:02 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Rear View Mirror Button Won't Hold
I've been having the same problem dude,...
I'm guessing that the mirror kits these days are not using the same adhesive as back in the 'old days' because until a couple years ago - I never had a problem. Like you, I've tried several different mirror adhesive kits and have even tried to re-attach the button under different conditions. ( warm-in the sun, cool-in the shade, Dry weather, Humid weather, ect... )
Old Oct 4, 2016 | 01:22 PM
86firebird350's Avatar
Car: 91 GTA
Axle/Gears: stock
This is what I used and it worked with no problems. What are you using to clean the windshield?
http://www.oreillyauto.com/site/c/de...rd=mirror+glue
Old Oct 4, 2016 | 02:11 PM
Chopski's Avatar
Car: 1989 IROC
Axle/Gears: 3:42
Might be worth going to a glass installer and have them stick it on?
Engine: LB9 305 TPI
I did this 3 years ago and it held for 3 years! In the Florida heat no less. It only took me the first try.
Old Oct 4, 2016 | 02:13 PM
Engine: LB9 305 TPI
I used nail polish remover to clean off the old glue, then cleaned the Windshield with glass cleaner. I scrapped the back of the button with a razor blade and sandpapered it after.
Old Oct 4, 2016 | 02:14 PM
Engine: LB9 305 TPI
At this point, you are probably right. I will try one last kit tonight and if it doesn't work, I'll take it to a shop tomorrow.
Old Oct 4, 2016 | 03:28 PM
Car: 91 GTA
Axle/Gears: stock
I'm not sure about the nail polish but the glass cleaner could be the problem. It leaves a thin layer of product on the glass to prevent dust, etc from accumulating. This could be keeping the glue from adhering to the glass as well.
I would use rubbing alcohol to clean both surfaces before applying the glue. It removes all contaminants from the surface. I also believe the kit I used included a cleaning solvent to use on both (probably alcohol).
Old Oct 4, 2016 | 04:02 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Did You Use The Activator On The Glass And The Button And Wait 2 Minutes For It To Dry And Apply Only 1 Drop Of Glue To The Button.
Old Oct 4, 2016 | 05:31 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Less is actually more, in this case. The activator or primer is important as well.
1Aauto
Sponsored Vendors
Jun 8, 2017 11:06 AM
thewizard
Oct 18, 2016 12:23 PM
KILLARACER34
Oct 9, 2016 04:44 PM
Dodgeman79
Sep 27, 2016 10:02 PM
NiG
Sep 7, 2016 08:13 PM
