rear mirror shakes at high speed
Car: 1989 Gray ttop GTA
Engine: 5700cc
Transmission: auto 700R4
hello
I notice this also: in the highway, I was maybe between 80 and 95 mph. The rear mirror started to brutally shake. You can see it in the video.
Is it normal? :/
Actually, it looks fixed and firm on the door.
Is it normal? :/
Car: 1991 Trans Am Vert
Engine: 5.0 TPI
Transmission: T-5 baby
Re: rear mirror shakes at high speed
its just the lens that is shaking right? My GTA used to do this. I never fixed it but was told it was common. the glue that holds the mirror to the housing has grown old and weak. they said to take something to pry and pop it out. never wanted to damage the housing so I left it alone.
Engine: 5700cc
nope, the whole mirror shakes. It's like it is not soldly attached to the door. Actually, if you touch it with the hands, it seems solid.
that's bad
that's bad
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
If those are power mirrors, the glass is mounted to the motor which is secured to the bracket holding it in place by . Any loose screws or worn mounting points can cause that shaking you are getting. Unfortunately the only way to fix or check that is by successfully removing the mirror without damaging it( not likely, but?) and tightening or fixing loose stuff and then replacing the mirror. I'd get a new mirror before trying any of that, but maybe you can get it off??
Good luck!
Good luck!
Transmission: Pro-built 700R4
I had an almost exact same issue. My driver's side mirror vibrated so much that I actually got used to not even relying on it.
However, it is actually a pretty easy fix. The culprit is most likely the two 10mm or 13mm bolts (I forget which size they were) that hold the mirror housing to the door panel. You access them by removing the inner door panel. You'll see the two bolts at that point. Just tighten them up and you should be good at that point. Make sure you don't over torque them or you can bed the mirror housing or the door panel.
Car: Firebird
Engine: 5737cc
Its not the mirror its the whole door skin in that area.It happens if the gasket under the mirror arm is broken.There's a tutorial here https://www.thirdgen.org/forums/memb...990-trans.html ...scroll down to the mirror part.That gasket distributes the force on the door skin.
The real problem in that video is why you are letting that van get so close
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Mirror mounting is as basic as 2 securing nuts with no adjustments so it's either mounted wrong, or something is busted/rotted. If you seen any obvious damage/defects to the plastic trim spacer under the mirror housing then it might be a good idea to get a replacement handy before starting,... because it's about time to pull the door panel off for an inspection and some adjustments !!!
JdubRS
Exterior Parts for Sale
Jun 8, 2016 09:44 PM
