Will 255's fit on all four corners ?
Old Dec 28, 2001 | 03:22 PM
RoadRocket L98's Avatar
Will 255/50/VR16's fit on all four corners of an '89 Formula WS6 without rubbing? Would you recommend this size on a 16x8 inch wheel? Thanks for any suggestions.
RRL98
Old Dec 28, 2001 | 03:44 PM
pontiac's Avatar
i placed 255 falken's to rear and those are rubbing to fenders while i'm doing some cornering with moderate amount of throttle
don't know about front since i'm still running 215's.
-P
Old Dec 28, 2001 | 03:45 PM
Eggplant Jeff's Avatar
255s in the rear is no problem at all. I think some people run 275s and even 295s without a problem (295s may require some slight inner fender massaging with a hammer).
The front is the only question. I have 245s on the front of my RS (16x8 wheels) without any problem. 255s are only slightly larger, it ought to be OK. Keep in mind though, not all 255s are made equal. I think my 245s are 245/50 or /45. 245/55 might rub. And different brands of 255 are sometimes not exactly the same width... a wider "255" might not fit when a narrower one would. Mine are BFGoodrich Comp T/A VR4s.
P.S. just saw the post that sneaked in ahead of mine. What size wheels do you have, pontiac? I think the 16x8s have deeper offsets than the 15x7s and allow a wider tire. I have 255s on the rear with no rubbing.
Old Dec 28, 2001 | 04:54 PM
DM91RS's Avatar
Car: 91 RS
I run 255's and have no problems front or rear. I have used Falken and BFG comp z/r's with no problems on 16x8 crosslace GTA type all front offset (puts the wheel farther out on the back)
Old Dec 28, 2001 | 06:39 PM
iroc5speed's Avatar
I'm running 255/50/16 Kumho tires and they fit fine, no rubbing.
Old Dec 28, 2001 | 08:01 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
iroc5speed: How do you like the Kumhos? They are the ECSTA Supra 712's right? I heard that they seemed to be a little narrower than other tires... I got some 16x8 IROC wheels and I plan on getting these tires for them.
Old Dec 28, 2001 | 11:27 PM
89WS-6's Avatar
Should. I know the fit on the back but should on the front to, becuase I have 245's on my front.
Old Dec 29, 2001 | 02:39 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
255/50/16's all the way around and the only rubbing I get is on the front sway bar when I turn too sharp,
Hotrodboba400
Dec 10, 2019 07:07 PM
Drone358
Dec 10, 2015 08:16 PM
New2Chevy
Sep 28, 2015 12:35 AM
tglennon11
Sep 23, 2015 05:30 PM
Formula_88AE
Sep 3, 2015 01:47 PM
